Have anybody the same problem with nero. From Version 6.0.0.23 on, I can't copy on the fly my own dvd's (data or video) . I have a
LG 8161B DVD-Rom Drive and a Sony Dru-500a. Nero always says disk is empty, but it is full. CD's and Commercial DVD's are no problem, only DVD-+R.
Are you sure that you have Nero set to the correct drive? I know it's a silly question, but lotsa folks make that mistake.
Have you cleaned the disc really well?
Have u tried dragging the files to your HD first?
Have u tried doing an ISO copy?
Issues with your OS or hardware setup can prevent u from doing an on-the-fly copy, so I suggest trying those other methods also to see if you can uncover some underlying issue that may be causing the problem. -
Had the same problem with Nero 6.0.0.8 I have the same LG DVD-ROM but a Pioneer 106D Burner and it will simply refuse to read the disk , if it's one of my own DVD-R's despite the disk being completely clean etc . My only solution has been to copy off the fly which results in the same problem which is only solved by setting DVD Shrink to No Compression and ripping everything to the Hard Disk and reburning the whole lot again .
Hi,
Whenever you use Nero 6 and it will not allow you copy the DVD disk in Nero Burn, then go to Nero Express to copy, I do like that 10/10 I can copy it.
Good Luck, 8)
Unable to disc copy with Nero 6 and Win 7
By cobra jet in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2011, 12:38 -
Nero freezes when trying copy dvd
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2009, 04:30 -
CD Copy with Nero Fails after a few burns
By kadzbiz in forum MediaReplies: 7Last Post: 5th Feb 2008, 20:46 -
Can't copy a (ISO) DVD I just burned in Nero
By perceptionist in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 22:49 -
burn with dvd decrypter but copy by nero ?
By GINZY in forum DVD RippingReplies: 2Last Post: 6th May 2007, 08:05
