I am new at this and am trying to understand, so please correct me if I am wrong.
Backing up a DVD requires 3 parts - rip, shrink, burn.
Question: Am I correct that the part of this process that is most critical to quality is the shrinking part? And that the ripping and burning parts don't really interfere with the quality of the backup (assuming that the backup works on my players)?
Thanks.
You forgot decrypting, unless you are not talking about DVD movies.
Decrypting might be considered a subset of ripping, I guess.
Shrinking is only necessary if the files are too big to fit on one DVD.
But yes, as far as video quality is concerned, the most critical part is shrinking.
Ripping and burning don't generally affect video quality.
Corrupted WMV Files - Header is missing critical data
By Avide in forum Video ConversionReplies: 4Last Post: 6th Jul 2011, 05:01 -
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
Critical Speed Loss
By saurio in forum DVD RippingReplies: 2Last Post: 21st Jun 2010, 15:17 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36
