  1. HI ALL and.... HAPPY NEW YEAR!!!
    i burned many dvdr without problem but when i try to read dvdr burned with other writer many times the nec 1300A recognize it as CD and don't read it
    i use firmware 1.08 and 1.09
    i use philips and sony media
    i use btc and sony writer
    i tryed the dvdr with other dvd reader (pionner, lg and btc) and all is ok
    my question is:
    is my writer broken and i need to change it ?
    or
    is my nec 1300A a bad dvdr reader and i buyed only a wirter
    thanks,
    Leo
    Dec 2002
    Did you close the session? If I don't close the session my DVDROM drive won't read the DVDR I just burned. But, my 1300a always reads it's own disks.
    I pretty much use RITEK G04's exclusively (-R 4x).
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. the dvdr is burned as disc at once
    i found another problem, when i finished to burn the dvd and start verify fase, the reading fase is very slow, i think 2x/4x max
  4. What firmmware have u got?
    Jan 2004
    Russia
    Hi!
    I have the same problem with reading some -r(w) written with other device Toshiba ds-r5002. I recently posted a question to NEC's support about not recognizing Verbatim -RW erased on Toshiba, and they say it is due to incorrect (erased or damaged) Manufacturer ID. As far as I understood, it meant the writer (Toshi) changes some disc info it, well, should not touch
    Can it be truth ? Is it the same with -R also ? I don't know yet.
    BTW, does anybody know why nd1300 can not write ANY disk at 1x (only superior speeds work) ?
