Hello to all!!!
I have a DVD with a short film that was filmed in 16:9 (filmed by a
Digital BETA camera and saved in a DVD) and when I open it with
PowerDVD, it plays as 4:3....(the only "solution" I found, was to
de-activate the aspect ration in PowerDVD menu and make the window
bigger manually....)
I have tried in the internet, and I have found the instructions to use
IFOedit. So, I changed the parameters from 4:3 to 16:9 by the use of IFOedit, I saved them (IFO and BUP created), but when I open PowerDVD
the effet (from 4:3 to 16:9) do not appear......
(when I check by IFOedit, they appear as 16:9)
Any idea will be very much appreciated !!!!!
Thanks in advance / Yiannis
As they were only 2 minutes apart and in the same forum I will assume it was an error, but please try to ensure you don't post the same question more than once. Other topic closed.
/Moderator - Bugster
Change Aspect Ratio
By wulf109 in forum DVD RippingReplies: 1Last Post: 7th Feb 2011, 18:12 -
Best way to change aspect ratio....
By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 10:33 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 13:14 -
How to change aspect ratio?
By crt in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 10:49 -
using ifoedit to change aspect ratio
By qpskfec in forum Authoring (DVD)Replies: 1Last Post: 29th Nov 2007, 11:32
