ok, i capture using picvideo mjpg without a problem.
I review it and/or edit it in vdub. but, when I go to encode it with CCE or tmpg, i get decompress errors. i've reinstalled the codec a number of times.
for fun, i made an avs script and loaded that into vdub. i was able to reproduce the decompression error.
has anyone else encountered this problem or have a solution?
thanks,
It's somthing about the way that Vdub records dropped frames.
I workaround it by frameserving the video from vdub. You could also re-save the stream using huffyuv if you has the time/space to accomidate. -
Thanks for the quick response snowmoon.
I'm not capturing with vdub, i'm capturing with avi_io.
my workarounds so far are, convert to huffyuv (as you suggested) and then recompress (a big pain) copy the file to another computer to compress (where i don't get the decompress error).
i need to find some way to remove every trace of the picvid codec on my pc and reinstall it. my guess is that running the uninstall isn't removing everything.
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 08:59 -
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 11:31 -
MJPG Decompressor
By Colton-Nan in forum Video ConversionReplies: 15Last Post: 25th Feb 2010, 11:27 -
Annoying blackscreen problem with AVS video editor
By in flames in forum Newbie / General discussionsReplies: 0Last Post: 5th Dec 2007, 00:10
