What a nightmare!!
Here's what I'm trying to achieve;
I have two files, details are shown below (this information was provided by the utility AVIcodec), and I want to merge'em and then burn them to a DVD-R so that I can watch the resulting movie on my DVD player. I don't want any fancy menus or chapters, I just want to be able to watch it on my television through my DVD player.
File 1:
File : 258 MB (258 MB), duration: 0:47:04, type: AVI, 1 audio stream(s), quality: 42 %
Video : 239 MB, 711 Kbps, 29.970 fps, 480*360 (4:3), XVID = XVID Mpeg-4, Supported
Audio : 18.77 MB, 55 Kbps, 22050 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
File 2:
I've tried using the latest version of NeroVision Express and my Pinnacle Studio 8, but without success. Twelve DVD-R's later and many wasted hours I'm on the verge of a nervous breakdown.
I then paid a visit to www.dvdrhelp.com where I've found some useful information, but I'm still stuck.
I've used TMPGEnc which seems to seperate the video and sound, but then whatInstead of just two files I now have four.
Just to add that I have refered to many of the articals contained with the web site but as a newbie I require a little bit more hand holding before I can take my first steps into the world of video/film/movies.
Please help.
Thank you
Ian.
Results 1 to 14 of 14
Hi Spoogle,
To my mind, you have two choices:
1. Join the two AVI files, encode to DVD compliant mpeg2, author to DVD (1 track).
2. Leave the AVI files separate, encode them both to DVD compliant mpeg2 files, author both to DVD as 2 separate tracks.
Joining: I believe (someone correct me if I'm wrong), that you can use VirtualDub to join the 2 AVI's.
Encoding: I found the following guide...
http://dvd-hq.info/Compression.html
...VERY useful for the settings in TMPGEnc to encode AVI -> MPG2.
I used Average Bitrate = 6,000, Max Bitrate = 8,300, Min Bitrate = 2000, 2 Pass VBR. These settings are a guide, as they depend primarily on film length, but also audio format used (PCM vs MP2 / AC3), subtitles etc.
Authoring: As you're new to this, I'd recommend TMPGEnc DVD Author for the following reasons:
1. I'm new to DVD creation too, used this, and found it pretty easy to pick up.
2. It's fully functional for 30 days, before you have to pay to continue using it.
3. It seems a popular tool / recommendation on this site - Hence loads of resource for help.
Note: mp2 audio is usually only playable on stand-alone DVD's that are of European origin. Get back if you can't use mp2, as there are other ways...
Hope that helps... Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thank you daamon for your advice.
I suppose, option 2, leaving the AVI files seperate will allow me a certain amount of flexability, just in case of a mishap, however will this affect the finished movie in any way?
Encoding
As for encoding, I read the artical that you linked to before, but it seems VERY technical to me. What with all the technical terms like lossy compression, PCM, AC3, DTS, VBV buffer, MP@ML, 4:2:0, DC component precision etc etc., when all I want is to transfer a movie to DVD.
Authoring
I took a brief look at TMPGEnc DVD Author software and the guide at http://www.polarhome.com:793/~afonic/tmpegencdvd.htm. I've read through this guide time and time again, but it doesn't state what to do with the seperate audio file that's created when using TMPGEnc. Does this mean it's only good for silent movies
I have two files an MPG1 = MPEG 1 (VCD), I thought this was supposed to be MPEG 2 for DVD video, did I miss a setting somwhere, and a MS PCM audio file.
Thank you
Ian -
Hi Spoogle,
As for encoding, I read the artical that you linked to before, but it seems VERY technical to me. ...when all I want is to transfer a movie to DVD.
Authoring - I've read through this guide time and time again, but it doesn't state what to do with the seperate audio file that's created when using TMPGEnc. Does this mean it's only good for silent.
If the sound isn't included in the encoded video file (like in an m2v file - same as mpg2, but no sound) then you can browse to select the desired audio file (be it mp2, wav (PCM) or ac3).
I have two files an MPG1 = MPEG 1 (VCD), I thought this was supposed to be MPEG 2 for DVD video, did I miss a setting somewhere , and a MS PCM audio file.
Given the original quality of your source video (42%), I believe that using higher bitrate settings in TMPGEnc to encode will not improve the quality, only take longer to encode. This is outside of my knowledge, so hunt around or post a question. It may even be the case that you'll end up making a VCD. I make DVD's from DV AVI (high quality) and so aren't too familiar with (S)VCD etc.
Carpe diem.
Originally Posted by gemmell
Yes, audio on DVD has to be at 48,000 Hz. Like gemmell says, use VirtualDub - it's pretty easy to figure out.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Use a RW disk for your first test burn.
Check the burned disk on the computer and on a TV(Stand Alnoe DVD player).
All I want to do is convert some sVhs tapes to DVD also. It it was simple or easy, I would be finished now. The more you learn, the easier the task becomes. -
daamon,
Was reading this post for advice on similar issue. When you say you'll have 2 separate dvd-compliants mpeg-2's to burn as 2 separate tracks, can you do something like this in Studio 8? In other words, can you have 2 separate tracks to put on the one menu?
Thanks. -
Originally Posted by ejm1385Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Sorry, I'm not familiar with Pinnacle Studio 8. Hopefully donpedro has helped...
@ Ian / Spoogle,
Why does audio have to be at 48000Hz?
Strange!?! When I try to convert File 1, see above, using TMPGEnc I get an error message saying the File XXXXX can not open, or unsupported. Any ideas?
I've used TMPGEnc which seems to seperate the video and sound, but then what? Instead of just two files I now have four.
Leoslocks also has a good point - using re-writeables to test on PC's and stand-alone DVD players (probably more importantly) will save you burning coasters and needlessly wasting cash.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
daamon
Apologies for the confusion, I thought I had used TMPGEnc to encode the files, but, alas, I hadn't.
I had been experimenting with other files and found it was a couple of them that I had encoded, not the files stated in the post. Guess I should keep better track of my files.
Ian. -
Hi Ian,
https://www.videohelp.com/tmpgenc.htm#problemsThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I have two files an MPG1 = MPEG 1 (VCD), I thought this was supposed to be MPEG 2 for DVD video, did I miss a setting somewhere , and a MS PCM audio file.Originally Posted by daamon
720 x 480 pixels MPEG2
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
Note that 352x240 mpeg1 is acceptable for DVD."Art is making something out of nothing and selling it." - Frank Zappa
Newbie questions on saving, converting, burning, etc..
By osb_tensor in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2010, 22:42 -
Sorry Newbie here: Help in Converting AVCHD to DVD
By JohnnyCat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 21st Aug 2009, 21:53 -
newbie looking to learn seeking converting and burning advice
By jim11757 in forum Newbie / General discussionsReplies: 16Last Post: 27th Feb 2009, 02:16 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 11:28 -
Newbie converting to DVD - help!
By photogman in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2007, 10:48
