HI there I am very new to DVD burning, I tried to rip a DVD movie using DVD shrink, however it is saying to me that cannot open the file cause the disc is protected, I thought that DVD shrink can just rip any DVD eventhough copy protected to hard disk. Is this correct? If not, does that mean I need another software to rip it to hard disk firstly such as DVD decrypter?
Another question is: Which one do you think is better using CloneDVD + AnyDVD ( I have these two programs already) or using DVD shrink and other softwares???
thanks
Welcome to the forum Cygnusice!
Try using DVDDecrypter or similar and ripping the DVD onto your hard drive and then using DVDShrink on the ripped files!
As far as the other software you mentioned is concerned, DVDShrink has the edge of being freeware. With respect to quality, i never had any issues with DVDShrink (especially with version 3) on a 32'' widescreen Phillips TV). Keep in mind that compression of more than 80% on the main movie will have some quality issues - so, those extras might have to go still frame!!!
Good Luck!!
LeoNapierThe Truth Is Out There - X Files -
I read from other topic that DVD Shrink can also decrypt an original DVD movie, if this is true, shouldn't it mean that I do not have to use DVD decrypter at all?
Cheers -
Do you have 3.0.5Beta or 2.3? 2.3 won't decrypt whereas 3.0.5b will.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
None of my DVD collection is copy protected? DVDShrink 2.3 has opened EVERY DVD in my collection.
DVDDecrypter is 9 times out of 10.... NOT NECESSARY.
If DVDShrink has trouble....it is usually at the beginning of a DVD. Just play the DVD in your computer's DVD player for a couple of minutes and the hang-up will most likey disappear. -
You're either using v2.3 with an RCE protected disk, v3.0b5 and your dvd player is not set to the same region as the disk, or you dvdplayer region has not been set at all (or something else and I'm totally wrong...cannot open the file cause the disc is protected.
A simple workaround is to play the dvd in your software player for a few seconds, pause it, and then start the DVD Shrink process.
v2.3 decrypts, but not RCE protected discs.2.3 won't decrypt whereas 3.0.5b will.
As hech54 already stated, this is true for most DVDs.I read from other topic that DVD Shrink can also decrypt an original DVD movie, if this is true, shouldn't it mean that I do not have to use DVD decrypter at all?
However, it sometimes happens DVD Shrink cannot read a disc, most often than not because it is damaged or dirty.
That's when DVD Decrypter comes in handy.
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 04:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 04:28 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 20:48 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 21:49 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 08:31
