Results 1 to 12 of 12
  1. my G4-867 build in superdrive is dead, all the CD or DVD i put into the machine will eject automatically. So i am thinking to buy a new machine to replace it. I saw a few reasonable priced internal DVD +/- RW in the market, but not sure will they work on my G4 or not. Is there anything i need to know for this replacement operation? Thanks!
    machine type :
    G4-867
    build-in superdrive
    running 10.3.2
    Feb 2003
    Bloomington-Normal
    From what I know you should be able to put almost any new drive in there and it will work automatically without a hitch.
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    pioneer's will work with NO problems
    the model you have can take 2 drives actually so as long as you put the superdrive on the TOP it will have no problems being a replacement for your current drive
    the 867 is an excellent machine and doesnt seem worth replacing the ENTIRE machine for just the drive... but then again its your mac
    hope this helps
    Mar 2003
    Here is a pioneer A06 $126
    http://www.livewarehouse.com/livewarehouse/shop/product.asp?dept%5Fid=21&pf%5Fid=%7B0A...77140E9D974%7D
    This should do the job quite proper
    Here is an install guide use the b/w G3 tower instructions
    http://www.xlr8yourmac.com/G3-ZONE/hival52x/install.html
  5. Member galactica's Avatar
    Jan 2003
    man!
    look how the prices have come WAY down!
    i have had my dvd burner for quite a while and at a whopping 2x burn it was 200+!!!!
    Mar 2003
    Originally Posted by galactica
    man!
    I paid $500 for my Pioneer A03
    and $350 for my sony DRU 500a
    Livewarehouse has the sony drives there also they have at least 10 dvd writers on that page for less than $150 just about the cheapest place I have seen without rebate
  7. Member galactica's Avatar
    Jan 2003
    http://docs.info.apple.com/article.html?artnum=26259
    here's apples documents on installing ANY part on the G4 867 MDD
    this will help you a little more than the G3 tower guide because this one is EXACTLY for your comptuer!
    its really easy....
    enjoy
  8. thanks guys, another question. will it work with NEC, LG or HP?
    Feb 2003
    Bloomington-Normal
    Should... and if not, return it.
    California
    Ya but do these drives work with iDVD? The Pioneer at livewherehouse says Windows Os, nothing about Mac Os. Now Macsales has the Pioneer A06 for $147 and it comes with iDVD. Would this drive from them be safer to buy? I use an External firewire A04 with Studio Pro on every machine I have (2 G4's and 2 Powerbook's) but I can't use iDVD with it (which until Studio Pro 2, was sometimes easier to use) Any ideas?
    seemeterryg
    Can hardly wait till Friday's trip to MacWorld in S.F.
    Mar 2003
    seemeterryg
    Yes it will work just fine check out www.xlr8yourmac.com for compatiblity for any drive (it works as long as you install it internally.)
    Macrumor had something on their page about non superdrive compatibility for external dvd writers with IDVD 4 but apple doesnt say anything about it so I think that claim is false
    http://www.apple.com/ilife/idvd/
    No drive will work with IDVD externally
    Sorry
