Hi again.
Any one managed to get material out of their 5100H?
I'm running Windows XPpro on a Dell Dimension 8300 (P4) with latest service packs, security patches and DirectX 9.0b.
The only material I can get out of it is NTSC, when trying with PAL I end up with a black preview screen and no frames captured.
The only program that I get an error message from is Scenalyzer it says something like "Capture driver is sending PAL in NTSC frames or vice versa you might want to upgrade DirectX"
Doesn't pioneer follow the DV standard or is it Microsoft that doesn't?
Hi!
I didn't have any problems with the DV-out and PAL material, I've been using an iBook with OS X and iMovie though. -
Look into these things in manual (page 96)
Input Line System
And try to setup (manual page 101)
NTSC on PAL TV to OFFPinnacle Studio 8 and DV home video editing (ver.9 already home) -
My mistake... It should be other way arround
Anyway... play with those settings.... and of cource your software have to be able work with PAL
Well I encounter the same problem what ever software I use, as they probably all uses Microsofts standard video capture API, DirectX.
I think the NTSC on PAL TV only affects the analog video output, but I've tried that one too with out success.
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Hacking Pioneer DVR-5100H (DVR-510H)
By Destroyer in forum DVD & Blu-ray RecordersReplies: 145Last Post: 5th Mar 2009, 14:46 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 02:59
