I have 2 folders of files for 2 separate films I wish to put on one disc. Each is onjly 2 GB so there is space for them, and they are both valid VIDEO_TS folders already converted and auhored.
I wish to merge these onto one DVD without having to re-encode the files, and hopefully without having to re-specify the chapters. Is there any software that will do this for me?
Allan
two come to mind...
1) Tmpgenc Dvd Author
2) Nero
both are payware with trials available.
you might also check the "how to author" section - see l/h side this page. -
I have both of these and had a try to do it but both insisted in re-encoding the files. I have authored both exisiting folders with Nero Vision Express already, but each has files which are named identitcally. I doubt I could simply rename them as the buttons etc. would not link to the correct film.
How do I do it with NV?
Allan
DVD Folders - Video TS & Audio TS
By bdr13278 in forum Authoring (DVD)Replies: 20Last Post: 21st Feb 2010, 12:40 -
Not getting Audio/VideoTS folders created for DVD
By LoafingOaf in forum ffmpegX general discussionReplies: 13Last Post: 30th Jun 2008, 19:23 -
how do install two folders video_ts in one dvd-r
By togood in forum DVD RippingReplies: 3Last Post: 13th Dec 2007, 05:58 -
Add folders to DVD
By marioval in forum Authoring (DVD)Replies: 1Last Post: 2nd Nov 2007, 17:45 -
Need 2 save folders in DVD Shrink?
By jyeh74 in forum Newbie / General discussionsReplies: 17Last Post: 13th Oct 2007, 23:25
