Hi
Is it possible to put more than 1 MPEG file on a VCD? And can you make a chapter out of every file, so each episode is a chapter?
Also, what if the file has a weird framerate such as 14 fps? Can you still put it on a VCD without losing sync between the video and the audio?
Spike
If you think you have it... but you don't.
If you don't think you have it... you still don't. -
as long as the file size of the combined number of MPEG's doesnt excede the size of the disc you are burning to, then yes you can put more than one MPEG on a VCD...and each file will be a separate "chapter" automatically...
at least that's the way it is when you use Nero
as far as the frame rate stuff goes that you're talking about, i have no idea...i'm having a few issues with frame rates and audio/video sync myself...
good luck
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 22:49 -
Editing and rendering with multiple frame rates?
By vid83 in forum EditingReplies: 12Last Post: 2nd Mar 2011, 03:20 -
Help Aspect Ratios & Frame Rates
By CTP-Crystal in forum Newbie / General discussionsReplies: 21Last Post: 1st May 2009, 18:10 -
Question about Blu-ray frame rates
By Mentasm in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Sep 2008, 11:16 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 18:47
