  1. Hi all,
    So I have this DVD that contains some TV episodes but it already has a "episode menu" I want to replace it one that Im making. I thought that was possible in DVD Lab. I started making the new menu and then adding the appropriate VOB files but everytime I try to add a VOB to the asset window, DVD Lab crashes. Im sure theres got to be an easier way to do this. I understand that its probably not as easy as "drag and drop" but I need a little help with this one. Is DVD Lab the program to use or is there a better one?
    TIA,
    Aaragon
  2. I personally demux the video and audio files before authoring in DVDLab. DVDLab seems to work best from the core streams.
    There are several ways to do this. VobEdit will do it or even DVDDecrypter.
    Good luck
