I opened the IFO i have in hexedit, and i see the line of number s at the top. Im thinking one of them is the region code, and just needs to be changed. I just dont know which one. Any ideas?
Q
"Good Luck 007"
In Memory of Desmond Llewelyn -
This sounds like a lot more work than necessary. Just drag the IFO file into DVDBackup, select the region you want, hit Process, and save the fixed IFO file in a different place.
is there a way to see if the region change worked?
Q"Good Luck 007"
Here is all I know you can get out of HexEdit and an IFO
VTS_01_0.IFO file hex address 200
Open your VTS_01_0.IFO in HexEditor,
Locate hex address 200
Make changes as need, then save.
Here is an example: 16:9, 740x480, AC3 audio
0000200: F9 00 00 01 00 01 00 00 00 00 00 00 00 00 00 00
Aspect Ratio
43 = 4:3
F9 = 16:9
Resolution NTSC (PAL)
00 = 720x480 (720x576)
1 = 704x480 (704x576)
0A = 352x480 (352x576)
0C = 352x240 (352x288)
Audio Coding
00 = AC3
02 = Mpeg-1
03 = Mpeg-2ext
04 = LPCM
06 = DTS
*This info is found on Ross's homepage (homepage.mac.com/rnc)
nothing about region code! The only way I know to do this is with IFOEdit and its not the region code thats not correct, its the RCE protection (which I understand to be the PAL/NTSC designation)
i had this problem where i just used DVDbackup set to region free did the dvd2one and mailed if off to a friend in england.
He couldnt play the disk and further investigation proved to me that the RCE protection was still on the disk! I opened the VIDEO_TS folder in IFOEDIT and click remove RCE and that was all it took
less than 1 min to do that in VPC -
I looked there, and tried it. Hmm. My vpc sucks. Its soo slow. Plus the register with microsoft thing keeps popping up, and i dont have the box n e mroe. so im sorta screwed.
Q"Good Luck 007"
odd on 1ghz it should be pretty fast....
sure its not a 1ghz PC but it should work well enough...
I dont know any other way to do it unfortunately....
Editing the chapter marks in a dvd ifo file
By jjulio1 in forum DVD RippingReplies: 1Last Post: 5th Aug 2010, 06:03 -
Repairing/Fixing .mov ideas or help with hexedit
By Jabus in forum RestorationReplies: 7Last Post: 9th Jun 2010, 21:53 -
Editing ifo.
By MaiOns in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2010, 04:59 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 17:54 -
Editing a dvd using Premiere Elements 3 IFO??!! BUP??!!
By wiseeye1 in forum EditingReplies: 2Last Post: 2nd Feb 2008, 10:07
