Hello, I have a question I hope you can answer? I have an Archos Jukebox 6000 Mp3 player that hooks up using USB. The problem is, I installed the drivers and all worked fine for about 15 minutes. Then, all of the sudden I got I/O errors when I tried to transfer files from it. I then uninstalled the drivers and tried re-installing them. Upon re-install I always get the blue screen that says "Driver IRQL not less or equal". I know the player is fine since it works on other PC's. If you have any clue as to what could cause this please help. My system specs are as follow -
Windows 2000 Professional SP4
Abit NF7-S Rev. 2.0
AMD Athlon XP 2500+ Barton
PNY Geforce4 Ti 4200
All current drivers installed
Results 1 to 1 of 1
USB Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2009, 15:52 -
problem with usb 2.0
By guitardan in forum ComputerReplies: 3Last Post: 2nd Dec 2008, 11:02 -
Problem with my USB ports...
By nhbfan12345 in forum ComputerReplies: 3Last Post: 6th Oct 2008, 18:15 -
Pioneer DVR-212D Abit NF7-S ?
By JockMcJock in forum DVD & Blu-ray WritersReplies: 5Last Post: 14th Jul 2008, 02:23 -
Vm Ware+Xp+USb:problem
By themaster1 in forum ComputerReplies: 3Last Post: 4th Jul 2008, 18:28
