What format should I convert a DVD to, in order to be able to edit it with Adobe Premiere? I tried Divx and Premiere had the 'illegal operation' error.
Any suggestions by the experts in this field?
The best format to edit would be anything that has little to no compression if you have the disk space to handle it. Try Huffy or DV. Divx is highly compressed, as well as mpeg so those are bad choices.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Video editing software that supports importing video with multiple audio?
By elgy in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2011, 20:32 -
Webex recording changes video to side panel. Can I edit with video editing?
By Teenotes in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2011, 13:32 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29 -
Video editing programs letting you create .m2ts files with VC-1 video?
By justin0324 in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Mar 2009, 23:24 -
Is there a video card that can handle both: gaming & video editing?
By randyannie in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2007, 16:50
