  1. Hello I'm using DVD Shrink 2.3 to backup U2 Live From Boston onto 2 DVD-R's (main concert). After using Start/End to cut it in half. Previewing the DVD files that shrink saves onto the hard drive, I get a screatching sound with the Audio. I could fit the full consert onto one DVD-R if I take away LPCM 2-ch English but then the consert doesn't sound as good.
    Oh and previewing without LPCM-2ch I have no sound problems.
    Any ideas how I can fix this? Can I use DVD Copy x palt without burning? Just saving to hard drive 1st?
    Regards,
    Ian
  2. you could use dvdfab to split the dvd into 2 disks.
    dvdfab makes it nice and simple.
  3. Hi again.. Thanks i'll give it a go
