When I try to make DVD sleeves or inserts I print them out and find out and a littl section of the side is cut off. I am not sure if this is the software problem but there is something wrong in the setup of the printer I am sure of it. I have a HP psc 1350v all-in-one printer and am using Memorex Expressit Software that came with the labels. I need an answer on how to solve it.![]()
You need to switch to A4 paper....and make sure you switch your printer's settings to A4 also.
I had the same problem myself. No amount of jockeying with printer
settings would solve my problem.
I switched to legal size paper and all is right with the world.
kiki -
Could be you need to alter from portrait to landscape setting on printer or software, as a dvd cover has more width than depth unlike A4 paper which has more depth than width
Not bothered by small problems...
Spend a night alone with a mosquito
Software ideas for full size DVD case sleeve printing please.
By EagleW in forum MediaReplies: 3Last Post: 29th Apr 2010, 02:15 -
How to cut out the text on a dvd video
By tealmarlin in forum EditingReplies: 1Last Post: 9th Nov 2009, 13:27 -
Cut DVD but sync problems
By buddycat in forum EditingReplies: 7Last Post: 4th Feb 2009, 23:18 -
How to cut out a part from DVD?
By DjuKa in forum EditingReplies: 8Last Post: 23rd Oct 2008, 12:03 -
Need to cut audio from DVD
By UPSdriver in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2007, 08:58
