Hi all, I've created various clips with Adobe Premiere Pro and trying to get the 'pause' picture on DVD-R to be perfect on TV. But there is a double, flickering image whenever I hit the pause button on my standalone dvd player.
- My source is ntsc and I produce ntsc format.
- I do not deinterlace my materials.
- I used Adam's method, ie TMPGENC to test whether I should use Upper or Lower Field and it came out Lower Field but my eyes tell me it is definitely Upper Field as all transitions turn out to be jerky if Lower Field is used. However if I ignore transitions frames, the clips all appear find with either Lower or Upper Field encoding.
I use Pioneer SA-633A (comes with progressive scan feature). Is it normal to have double, flickering image when I hit pause on my Pioneer? If not, what am I doing wrong? I want to create 'perfect pause' clips on my standalone.
Really hope someone can assist me on this as I have created so many test clips over the entire weekend and still can't get it right. All advice will be most appreciated!![]()
Results 1 to 1 of 1
Software:
Adobe Premiere Pro - capture stills & motion, edit, render
Adobe Photoshop 7.0 - edit stills
TMPGenc Plus 2.5 - encoding, splitting mpeg
VCDEasy 1.1.5 - stills to mpeg, interactive menu, SVCD cue/bin
MOTV 2.10
Nero 5.5.8.2 - burn image
dvd player without play and pause on screen
By gamazz in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Mar 2012, 14:35 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39 -
Blu-Ray burns perfectly on DVD writer excedpt for first 3 seconds
By andrebengrove in forum Blu-ray RippingReplies: 1Last Post: 8th Mar 2009, 10:39 -
Pause/Record on DVD recorder controlled by camcorder?
By maveni in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jan 2009, 10:27 -
submux output avi file no sound on standalone DVD player
By sigmma in forum SubtitleReplies: 2Last Post: 24th May 2007, 05:19
