I'm going to get one of these burners, but which one comes with the best software?
-lg 4040b
-pioneer ao6
-sony dru-510a
well if you are going to do dvd copying. most of them don't come with very good software for that. well except for burning software. so it shouldn't really matter if that is what you are looking for.
I have an lG4040b. Software bundled with it not that great - I do not use it.
For example, create a DVD backup using DVDshrink. Burn it using bundled software neoDVDplus5 - get lots of pixel effect errors in DVD player. Yes could be a media/player issue but . . . burn same image using nero v5 using same media and get no errors on playback (make sure use nero in wizard mode though - not techie mode - still have not figured this one out). If burn an "extras' DVD with lots of differnt VOB sequences neo will only burn one set of vob's and ignore the rest = junked disk. Nero no such issue.
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
