hi, i was hoping there is an easy solution to this!!!
Basically i have a few dvd's, on my comp which are ntsc, i can burn and play on my dvd player fine, only thing is, coz its ntsc i have to use a different connection, therefore picture isn't as good.
I have a sony davs500, it only has s-video out and the 3 wire out(red, white and yellow) I forgot the name for that.
When i play ntsc using s-video, pic goes black/white, so i have to use the other connection to watch it in colour and obviously it isn't the same pic quality.
So i was hoping if there was a way of converting the ntsc to pal.
I know one, re-encode, but surely there must be an easier way of doing it, is there?
thanks again for any help, always appreciated
You have to re-encode. The fps as well as aspect and other things have to be changed. No way around it.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
