Hi!
Hi!
I've encoded a few divx files with TMPGenc to svcd and then I wanted to burn them as svcds on a dvdr disk.
I downloaded svcd2dvdmpg and tried to make the svcd files dvd compatible here. Everything seemed to be working fine and I then authored them using Ulead dvd movie factory.
However, when I wanted to play the dvd on my standalone dvd player the picture was great, but there was no audio.
Where did I go wrong?
There was no problem with the audio on the svcds before the conversion.
Should I change any setting in svcd2dvdmpg?
I'd be grateful for some help, because this is getting quite frustrating.
Nille
This is a problem from Ulead dvd movie factory. What svcd2dvdmpg does is make 1 file with audio and video in the right format or 2 files 1 audio and 1 video file depending on the settings (Program Stream: 1 file, Elementry Stream: 2 files )you used.
You need to put this input in to Ulead dvd movie factory and author If you don't have audio you either:
1. You used the Elementry Stream setting in svcd2dvdmpeg and forgot to load the separete audio file in to Ulead dvd movie factory
2. You have a setting wrong in Ulead dvd movie factory and then you need to read guides about Ulead dvd movie factory.Greatings,
Yf
no audio after conversion?
By bviruet in forum ffmpegX general discussionReplies: 1Last Post: 15th Apr 2008, 02:25 -
No Audio after conversion
By gcam in forum Video ConversionReplies: 6Last Post: 19th Feb 2008, 14:53 -
.ts conversion - no audio
By saintloup in forum ffmpegX general discussionReplies: 1Last Post: 14th Feb 2008, 17:27 -
Um, now what? I'm stuck - SVCD2DVDMPG usage
By Hal05154 in forum Video ConversionReplies: 4Last Post: 13th Aug 2007, 09:59 -
Audio framerate conversion?
By pYShTr in forum AudioReplies: 2Last Post: 28th Jun 2007, 12:05
