  1. I have DVD Shrink and Nero 6.0. I have been able to pull selections off of assorted DVD's and burn them. What I need is a program to edit each selection as to the beginning and the end of the selection, do a fade in and fade out and, if possible, equalize the volume of all the selections. Something like Nero can do with audio files with their Wave Editor.
    I see DVD labs mentioned a lot here. Does it have these capabilities? If not, what will work?
  2. As far as I know there is not a program that can edit VOBs like you want.
    That kind of thing is done before the authoring stage either on the AVI or MPG with an NLE App. like VideoDeLuxe or Adobe Premiere or Vagas.
  3. I Believe TmpGenc DVD Author will accept Vobs and allow you to set start and end points. I don't think it will allow fades or any audio equ tho.
