First I apologize for the long post, but I have read,read and read some more, downloaded software bought software and borrowed software.
running amd 2200 xp with 1 gig mem, 120 gig hard drive, buslink internal dvd +/- r/ rw- cd r/rw-speeds dvd=4/2.4/12- cd=16/10/40 which is a nec dvd-rw nd-1300a. programs are, any dvd 3.2.11, dvd decrypter 3.1.9.0. dvd shrink 3.0. dvd x-copy 1.0.0.1 clone cd 1.1.7.1 nero 6, dvd2dvdr, dvd region lite.. have downloaded and read all guides at least a dozen times. have tried all combo like clone dvd and any dvd, get error: udf 5 65536, same error with clone and dvd region lite. have tried dvd decrypter and nero = eror copy protected, dvd xcopy and nero = copy protected. running with any dvd in background and also tried with region free running in background. attempting to back up monster,inc. can watch on computer using power dvd, can copy files to computer and watch thru power dvd, just can not burn to disk. have been trying for about three weeks and have ruined 50 tdk dvd-r disk. please help. thanks to all in advance.
Hello,
I donīt know the answer to your problem, but use a DVD-RW, until identify a solution for your problem, instead lost a lot discs.
good Luck,
Wood -
if you're getting copy protect errors, it sounds like you aren't ripping the dvd correctly.
are you ripping all files to your hd using decrypter? -
yes I am ripping all files to hard drive, have separate folder they are ripped to, player is same as burner, insert dvd, rip to hard drive, burn to dvd-r, settings used are those that are stated according to guides downloaded. guides used are clone dvd and any dvd by mad bob, lord smurf's dvd decrypter/dvd shrink and burn nero. doom9 decrypter and nero burn. please advise if these settings need changes or if another guide should be followed thanks in advance. I am not sure about stand alone players because I can not even get copy to burn more that 7%.
Is there a patch or region free option in DVD Decrypter that has not been set ? You could try ripping using Smartripper.
If in doubt, Google it. -
yes DMA has been set, dvd decrypter (css cracking method) is set to I/O key exchange-> brute force. Thanks.
Newbie Question on Burning Bluray
By discover in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2012, 14:35 -
Newbie burning issues....
By simonkarios in forum DVD RippingReplies: 8Last Post: 16th Aug 2011, 13:06 -
Help a newbie with BR burning... please.... :)
By mefistofel_666 in forum DVD & Blu-ray WritersReplies: 8Last Post: 3rd Dec 2009, 16:11 -
Hello newbie here needs help with burning on Vista
By Seekyr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 18:57 -
Newbie Burning Failing
By mearm in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2007, 03:40
