  1. Ok, here's my problem. I have just used DVDShrink on The Fast And The Furious, main movie only. Can I use Roxio Easy CD & DVD Creator 6 to burn? or do I have to make an image with IMGTool?
  2. i use roxio cd and dvd creator 6 to backup movies and haven't had any problems..i create a dvd shrink folder with a sub folder video_ts were i put all the dvd shrink files in my directory..click onto creator classic menu at the bottom of the roxio 6 creator and drag the files in the directory were you have the dvd shrinked (video_ts) files on the top window and drag to the bottom window and retitle the dvd then press the roxio burning icon when ready.
  3. Thanks for the reply. I went on another forum and somebody had said the same thing and I just followed his instructions and burned my first DVD!!!
    I'm no longer a back-up DVD Virgin!
