hi, at times when I unite some mpeg files with TMPGEnc the duration and the dimension of the new file it is inferior of 3-5% to the sum of the single ones: why? (maybe it trims the pieces with problems, even if at times it doesn't seem they are in)
instead if I unite some avi with virtualdub the dimension of the file it is correct, but the counter points out a time almost double than real
Results 1 to 1 of 1
TMPGEnc Problem - navigating one frame at a time
By ereiamjh in forum Video ConversionReplies: 4Last Post: 28th Jul 2010, 08:55 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 14:08 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48 -
problems with avc to mpeg-2 in tmpgenc xpress 4.0 - more than 3x run time?
By NoFace in forum Video ConversionReplies: 3Last Post: 18th May 2008, 21:01 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 22:08
