I'm trying to convert a XVID file to DVD, I am following the guide that I have found (on this website) following it to a T but it still ain't working.
I get this!
For some reason it keeps making the file like 200mins? Just noticed that!
I experienced the same problem about a week ago. I solved it by uninstalling and reinstalling ffdshow. I also had to raise the priority level of the directshow filter to a "+1" after reinstalling ffdshow. Prior to this, XVIDs played just fine without me adjusting any priority settings in TMPGEnc Plus.
Now, the play time is displayed correctly and I am able to convert XVIDs to mpeg1 or mpeg2 with no problems.
It may not hurt to uninstall (delete) TMPGEnc and reinstall it if you are not using ffdshow.
I think my problem may have occurred because I installed PowerDVD 5. (I have PowerDVD along with Sonic CinePlayer installed on my computer.)
All is well now.
*Oh...you may want to load the "unlock" template which is found in the "extra" folder, so you can adjust the bitrates for the video and audio. I usually use 224kbps for my mpeg2 encodes. After you unlock the settings, save the template under a specific name and it will appear under "other" the next time you open up TMPGEnc. -
I came across this page, farting around while my Bronco's were getting their butts kicked. Look closely at what XVID-1.0-Beta 3 fixed.
Changelog:
- Large filesizes now work correctly in 2pass.
- Fixed possible out-of-bound-reads in 2pass.
- Bframe decoding fix - sometimes bframes were referencing wrong future macroblocks.
- Checking "use keyframe" in a zone now only makes the zone starting frame a keyframe.
- Internal pixel aspect ratio fixes - added display aspect ratio (for anamorphic encoding).
Currently you'll need mplayer, vlcplayer (or 3ivx/Nero DShow filters) for correct playback.
- Colour space fixes.
- Directshow updates: brightness slider, postprocessing, output colour space choosable.
- Some more sse2 optimization for P4s.
- 2pass ratecontrol overhauled, including fast first pass.
- User selectable turbo mode. *silent update: 17:15h MET, 26.12.2003: updated dshow decoder
I use two pass VBR for my encodes so I looked at my settings in TMPGE and sure enough, my direct show was moved down and I was using my XVID CODEC for decompression. I removed my old CODEC and installed this Beta version and the problem went away. I was able to open the same file as yesterday but it read right. I then moved direct show back to where it should be...
Source image format is not acceptable (VDMOD, XVID, AC3)
By stlolth in forum Video ConversionReplies: 8Last Post: 23rd Aug 2010, 10:22 -
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 16:16 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Help me! I can't play file *.mds file after i 'mount image' using daemon
By i_nui in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 13:04 -
VIBE EN306TV-S Media Player has problems with Xvid file playback.
By Timfoxx in forum Media Center PC / MediaCentersReplies: 1Last Post: 6th Aug 2007, 21:34
