I've tried backing up two movies Matrix Reloaded & Deer Hunter to no avail. I am a newbie to dvd recording but I've spent almost 20 years in i.t. so no stranger but I have to admit defeat and ask an expert.
I use dvd decrypter and decrypt all files on dvd.
Then use dvd shrink to re-author movie to fit on one dvdr.
I then use nero6 to burn the files which play fine on my pc but both my dvd standalone players don't recognise the burned dvdr.
I've used a high quality dvd-rw disk for testing and several different quality dvdr's.
Any help or advice would be greatly appreciated
I JUST did Matrix reloaded and I used dvdshrink (skipped dvd dycrypter) and burned with nero 6...no problems. I dont know why you used dycrypter in the first place. Are you burning to a '-' or a '+'? Hope this helps!
If at first you don't succeed; call it version 1.0 -
What B1TCHM4GN3T said and I would assume your DVD players are compatible with your media? (DVD players on the left side of the site)
Your standalones might not play DVD+/-R at all. Some dont. Check the DVD players link to the left. Older players are the one that tend not to I believe. Though some new ones dont either. If you have been using minus disks try using plus disks assuming you can burn them. Or the other way around.
Good point REDWUDZ, as I forgot to throw that in! (about compatability with his player)
HD video to DVD procedure
By feh in forum Authoring (DVD)Replies: 5Last Post: 9th Aug 2009, 23:48 -
Cropping Video (Best procedure) ???
By Datahead in forum EditingReplies: 5Last Post: 7th Jul 2009, 18:53 -
Help the specified procedure could not be found error
By mn072065 in forum ComputerReplies: 6Last Post: 7th Oct 2008, 21:14 -
DVD Shrink with DVDStyler Procedure?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 6th Sep 2008, 11:52 -
New posting procedure for videohelp?
By yoda313 in forum FeedbackReplies: 7Last Post: 16th Aug 2007, 01:21
