Hi,
I want to try to create an svcd with lsx 3.0, but it seems like there is no possibility to set the resolution...???
I want to convert some of my divx movies, but since they're all 640*356 or something, i've got a problem.
Any suggestions??
blipp
Fear leads to anger, anger leads to hatred, and hatred is the path to the dark side
-Yoda -
You can adjust the resolution with LSX or CCE, you have to do it elsewhere and frameserve to your encoder, so for divx you might aswell use vdub, the guides are on the site....
Thanx.. I was hoping there was another way around. U lose alot of speed when frameserving.
Anyway, I have another problem also... When encoding with LSX the colors on the encoded stream are, at times, completely wrong.. The picture is either blue or green and so on. What causes this???
How can I fix it?
Plz reply, as LSX gives me decent results at a MUCH higher speed than tmpegenc.. I'm only experimenting though, have used tmoegenc many times before..
Thanx in advance!
blipp
-Yoda -
vdub frame server >> lsx seemed to be alot faster than tmpeg >> mpeg2.
I encoded a 21min clip in less than 30min, my res was 320x240. -
By the way, it's not really the frameserving that causes the slower encoding times. It's the resizing and other things you add to the script (ie; borderss, de-interlacing, etc) that slows things down.
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 17:51 -
Windows Media Encoder - 2 Pass Encoding Problem
By Xenon77 in forum Newbie / General discussionsReplies: 4Last Post: 13th May 2009, 17:51 -
Windows Media Encoder: AVI to WMV Two-pass problem
By apoon204 in forum Video ConversionReplies: 1Last Post: 24th Mar 2009, 03:45 -
Problem with x264 lossless file creation
By algee2k8 in forum Video ConversionReplies: 4Last Post: 28th Oct 2008, 11:55
