  1. Do any of you guys change the settings on this program? Is so, what are they?
    Cheers
    Oct 2003
    Central Texas, USA
    On the start screen, click on stream processing and select or de-select the subtitles and audio streams you do or don't want. I recommend unchecking all subtitles and all languages cept yer own.
    ISO Mode - For making a copy of the movie only when it is less than 4.37gb (DVD5). In the ISO mode settings, all 4 boxes should be checked and file splitting set to AUTO. You can rip AND burn in this mode.
    IFO Mode - For ripping the Movie-Only off a DVD, either DVD5 or DVD9. On the IFO mode settings tab, all boxes on the left need to be checked, and on the right, ONLY stream processing is checked. If the movie is more than 4.37gb, it must next be compressed. Can't use DVD Shrink when files are ripped in IFO, but you can use DVD2One.
    FILE Mode - For ripping the entire disc, movie, menus, extras and all. (If you intend to compress with DVD Shrink, you must use this mode) Select files set to ALL, multi-angle processing NOT checked, 4 boxes on bottom left all checked. On right, search set to 50,000.
    Hope this helps.
  3. It helps a great deal mate thanks, what version are you using tho just so I can make sure all the boxes that you told me to check are in the same place.
    Cheers!
    Oct 2003
    Central Texas, USA
    I use 3.1.9.0, which is the latest version. From what I can tell...looks wise...it is the same as the last couple of versions.
