hi. how can i copy a movie from dvd+ disk to a dvd- disk? at the moment, i get movie but no sound. details below
Video : 0.0 B, 7500 Kbps, 25.0 fps, 720*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 0.0 B, 256 Kbps, 48000 Hz, 2 channels, 0x2000 = AC3 DVM [0x80], Supported
tnx in advance,
kevpc
Where do you get no sound, on your standalone or on your PC ?
Could be that only the dts soundtrack is there and some players dont support it. A lot will depend on the source of this file, copyed by you or downloaded, was it burned by you?
Cant see how changing from a + to a - format disk will bring the sound back
Not bothered by small problems...
Spend a night alone with a mosquito -
tnx for reply. 'original' is burnt to dvd+r. wanted to put to dvd-r. had no sound on puter or standalone. trying different codecs in hope of getting to work.
regards,
kevpc -
Sounds like the origonal files have been messed up....
Not sure you will be able to get any sound if it wont give any now..Not bothered by small problems...
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
