Ok here is my problem I'm having, when I try to burn a movie it tells me that the VIDEO_TS.IFO Is bad. I've tried different softwares and I get the same result.
Question= Is there a way that i can create a new VIDEO_TS.IFO?
I've tried ifoedit but it seems difficult to use, is there some easier way to create the new IFO files for the whole thing?
§î®Th®ăsh€®
Ifoedit is easy to create
open VTS_1_0.ifo with ifoedit
Click on the top right VOB extras button
Click on create new ifo's
click through the OK's
let it process
Now open the new VIDEO_TS
click on the button on the bottom get VTS sectors
save and burn
make sure you have your VIDEO_TS folder with these files in it
Sorry if this isnt easy to follow did it from memory. -
Thank You for the quick response I will check out both ways.
Again Thank you for the assist.
§î®Th®ăsh€® -
I had this problem, I used TMPGEnc DVD Author, just dragged the .VOB files in and it write the rest for me! Burnt to a disc using Nero 6.
Job done!
Is there is a shorter and easier way please let me know as this was my first attempt which proved sucessful but a tad slow, also watch out for that TMPGEnc DVD Author, you have to make your own chapters! Mine is copied with no chapters cause I forgot
hehe Nevermind!!
DVDslideshowGUI stopped creating VIDEO_TS. IFO & BUP files
By gobettee in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2012, 15:52 -
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 07:04 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38 -
creating .ifo from .vob files and keeping menus
By vishalpatel1 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2007, 08:40
I've tried
