Hi,
I'm a new owner of Panasonic DMR-E60. Unfortunately from a missinformation from the seller I thought I can record straight onto the DVD-RW. I specified this 3 times, and they assure me " Oh yeah, no problem, is working great ! " Tried home, and it was working but no so great , I mean not at all with DVD-RW.
Anyway it seems to be a good machine, especially I want to have firewire input to transfer my movie from camcorder to DVD-R writer ( actually I want to transfer from computer right from timeline to DVD-R writer but it seems not to be possible, and I really hate this).
My question is if I copy something on DVD-RAM and I want to copy in next step to DVD-R what should I do, or which is the best method to do this, do not loose quality ( at all, or as much as possible) ?
Somebody told me I can use a different DVD-RAM palyer machine and then transfer to Panasonic E60 to copy DVD-R. OK, but what about the quality ? because for the maximum quality I have to use SVHS.
Do I have to use a DVD-RAM computer player ? and then copy into DVD-R computer DVD recorder ?
Thank you very much, I appreciate your help![]()
Try look in posts about transfering from RAM to DVD... or posts about Panasonic. This issue was discussed couple of times already.
Sorry for missinformation .... You should have come here first and readPinnacle Studio 8 and DV home video editing (ver.9 already home) -
Actually I did come here and read. That's why I triple ask those sellers, and they assure me this unit will work with DVD-RW. For a moment I thought is something new, or new firmware update that's why I swallow the ball.
But hey, I'm still happy with this overall -
Still after 4 hours of search on this forum, I can't find the straight answer to my question. All opinions of course count, but let's say informative only. Everybody say how to do but not in the best quality ways.
So :
Best quality method to transfer from DVD-RAM to DVD-R ? -
https://www.videohelp.com/forum/viewtopic.php?p=728735&highlight=ram+panasonic#728735
https://www.videohelp.com/forum/viewtopic.php?p=733395&highlight=ram+panasonic#733395
https://www.videohelp.com/forum/viewtopic.php?p=749768&highlight=ram+panasonic#749768
https://www.videohelp.com/forum/viewtopic.php?p=759482&highlight=ram+panasonic#759482Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
1) record to dvd-ram.
2) Copy everything to computer with a dvd-rom that can read dvd-ram. You can get a Toshiba dvd-rom for about $40.
3) Use Tmpgenc Author to author the vr_movie.vro file. You can download a trial version of Tmpgenc Author. It is good for 30 days.
4) Use Tmpgenc Author to burn.
Best Quality Method to Convert DVD to AVI
By abazabam in forum DVD RippingReplies: 42Last Post: 20th Dec 2008, 13:39 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 17:32 -
Copy recorded DVD-RAM to DVD-RW?
By Trollheart in forum MediaReplies: 11Last Post: 15th Apr 2008, 14:32 -
.tivo to DVD, I don't want to lose any quality. Which method is best?
By topho in forum Video ConversionReplies: 10Last Post: 10th Jun 2007, 16:53
