Sorry about the lame title...
Anyhow, I backed up one of my DVDs using DVDShrink 2.3 in Full Disc mode. The DVD is a little bit over 4.7GB so I only had to remove unwanted audios/subtitles, and compress extras to get the backup to fit one disc. Then I burned with Nero 5.5.10 and it plays fine on my DVD player and PowerDVD.
Here's my problem: When I was backing up the DVD, I removed audio 1 and 2 (foreign languages) and kept audio 3 (English). So when I play the back up DVD (either on PowerDVD or DVD player), the movie plays with the default audio (audio 1), which I removed. To play English audio, I have to go to setup and manually pick English (audio 3).
Is there a way to get the English audio (audio 3) to play by default?
DVD95Copy,Elby CloveDVD upto version 1.2.8.4,and Nero Recode will correct the ifo so that the english stream plays by default.
Re-compressing with either of those programs will correct the ifo file so that only the audio stream you kept appears in the ifo files.
Since your starting with a 4.37GB directory they won't really transcode but in creating the new directory they will corret the ifo file so that only your english track is present an will therfore play by default.
Assign default audio and default subpicture streams for movie only backups.
By mattstan in forum DVD RippingReplies: 12Last Post: 11th Sep 2012, 04:59 -
VlC became default audio player, some how, but I can't default 2 foobar?
By Denvers Dawgs in forum ComputerReplies: 1Last Post: 17th Sep 2011, 17:38 -
I need to make default uncompressed audio again!
By Artas1984 in forum AudioReplies: 1Last Post: 8th Jan 2011, 16:04 -
make ffdshow default
By mrcoolekin in forum Software PlayingReplies: 4Last Post: 26th Nov 2007, 04:54 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 22:56
