    May 2001
    London, UK - Bonn, Germany
    I bought myself a Pinnacle PCTV Deluxe - installed it (with the typical problems) and managed to capture without AV sync problems. I captured several videos which I then edited and burnt to DVD-R (using Womble, Maestro and Nero). Testing the DVD-Rs on PC was good and I was surprised at the good quality - however playing them on my Pioneer DV656 and DV636 standalone players was a shock - they will play but the video screen is like below - the audio is normal
    normally I would say with a normal pc that this is a codec problem - but with mpeg2 and playing on a DVD player?
    Can anyone help?
  2. I can't help but I own this unit too. It is in the box waiting for miracle
    May 2001
    I gave up and returned the Hardware - got instead the Moviebox USB
    and at least this works - captures are of good quality and the software is better too.
    May 2001
    If your caps played fine on the computer, and authored okay in DVDMaestro, then your problem lies elsewhere than the card. You didn't give near enough info to even hazzard a guess.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
