the question is can i fit 2 700MB movie files onto a dvd?
i converted the two files using TMPGenc and i set the size of the file output to 48% for each file, each ended up being just over 2 gigs each. but when i went to convert both to a video_ts file the total output came out to over 5 gigs.
so now is there neway to fit that video_ts file onto a dvd disk? or am i gonna have to start from scratch again? i would just like to know before i delete all the work that took so long to do, any help is appreciated. thanks
lol i thought that was the obvious choice, but i figured it was only for ripped dvds
When I backup my vhs tapes to dvd and I want two movies on one dvd I author both mpegs in TMPGEnc DVD Author and ignore the warning about the file size being to big when I save it. Then I use DVDShrink to reduce the file size to fit on one dvd.
Yes.Originally Posted by vspec
And what authoring app did you use for that. Some will convert the audio to uncompressed PCM. increasing the file size. You want to keep the compressed mp2 audio in the original mpeg file.Originally Posted by vspec
As suggested, you can use DVDshrink. But in the future you probably want to look more closley at your process if you want to take full advantage of the DVD medium.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 03:09 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 20:48 -
Adding subtitles to a BIG Avi file and then burn to dvd(?)
By Hal05154 in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 15:15 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53
