i have a nec1300a it takes 14minutes to burn a full dvdr at 4x is this the "normal" 4x speed?
when ripping it never goes faster then 3.0x using dvddercypter any idea why?
Results 1 to 9 of 9
I have a pioneer 106 and that's about the times I get.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
i got the nec 1300a and yes, 14 minutes is normal at 4x burning. the ripping speeds of dvd writers has been covered in many threads, u'll be best off gettin a dvd-rom for ripping but u might be able to increase the speed with herries hacked firmware(which is wut i use).
http://www.herrie.org/
josh -
okay thanks
I hard hacked firmware shortens the life of the drive? is this true? -
No, untrue.
I don't know why DVD burner manufacturers purpose limit reading speed. It was like that with CD burners for a long time too. I think it has something to do with the damn RIAA/MPAA, to be honest.
- Gurm -
Okay so the hacked firmware will be better then the current (1.09 i think) offical firmware? Which flash do i need?
14 minutes is DAMN good wouldn't you say for a movie over an hour long at least? Wanna go back to "real time" with VHS tapes?Originally Posted by simon1987
"If it aint broke....don't fix it" -
burning time is fine i dont have a problem with that.
but when i got my dvd writer because my dvd reader was failing, and the writer rips sooooo much slower then the reader use to -
Try a lite-on DVD-rom, fast and cheap and less wear on your burner.Originally Posted by simon1987"Art is making something out of nothing and selling it." - Frank Zappa
How to fix incorrect time? MKV rip displays as 14+ hrs long in all players
By elcoyoteloco in forum Video ConversionReplies: 2Last Post: 6th Feb 2011, 13:11 -
Help reset my expectations - how big the rip will be, time it takes to..
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 26th Nov 2009, 14:10 -
Read/Write at the same time
By mis3 in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Oct 2009, 11:29 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 21:28
