I used DVD decrypter than NERO Digital and made image file. I try to burn in Nero digital video and keep getting file larger than 2 GB error.
Any ideas what I am doing wrong?
Thanks in advance![]()
If you're using Windows 95, 98 or ME your disk is probably organized using the FAT32 file system, which doesn't support files larger than 2 gigabytes. You should use Windows 2000 or Windows XP, which uses the NTFS file system. While NTFS does have a maximum file size (which I cannot remember) it is MUCH larger than 2 gigabytes.
Yup, you're right. FAT16 only supports up to 2 gigabytes.Originally Posted by ghoster
Help with large TS file
By mejallen in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2010, 19:44 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning large file onto CD or DVD
By Tom in HD in forum MacReplies: 3Last Post: 2nd Jan 2009, 15:06 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 10:29 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2007, 23:54
