using tmpengc, when I'm in the source-range window, and I set the end frame to 91550(total is 183101), but then it just jumps back to zero. and if I try to drag the pointer to the middle the program freezes...what could cause this?
The file may be corrupt. Try running DivXRepair against the file. If there are any errors (bad frames, etc.) it should correct them. I always run DivXRepair after downloading and before attempting to work with the file.
http://divxrepair.sourceforge.net/ -
I sorted it out, just a little pointer missing in the guide I was using...
Problems converting MP4
By Nikar in forum Video ConversionReplies: 4Last Post: 17th Jul 2010, 11:39 -
Different converting problems
By saiden22 in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 12:29 -
Burn in subtitle in a AVI div-x film
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2007, 10:02 -
Problems converting from MP4
By bboypkj in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 20:57 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17
