If i add two files on one project with Tmpgenc Dvd Author will the files run one after another without stoping?.This would be handy for d/loaded movies in two parts.
Also if the two files a larger than a DVD will Dvd Author downsize the files to fit on one disk?.
If not is there a program i can use to make the two files smaller without losing quality so that they do fit on one dvd.It must bit fairly easy to use as im not very good on birates and stuff like that.
Just add both clips to the same track. One will follow the other with a brief pause. Author the DVD and ignore the warning about it being too large. Use DVD shrink to fit the results to one disk.
TMPGEnc DVD Author question/
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 22nd Sep 2008, 14:58 -
New TMPGEnc DVD Author Question
By Robert Simandl in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2008, 08:47 -
(Picture) Tmpgenc DVD Author 3 Question
By Maikeru-sama in forum Authoring (DVD)Replies: 0Last Post: 3rd May 2008, 19:20 -
TMPGEnc DVD Author 3 Question ...
By ZaYoOoD in forum Authoring (DVD)Replies: 5Last Post: 3rd Dec 2007, 08:17 -
By newtie in forum Authoring (DVD)Replies: 1Last Post: 4th Sep 2007, 10:49
