Hello,
Is there a simple program that will tell me if an mpeg is within the parameters to be authored in Ulead MF2? I have a lot of mpegs I want to burn to DVD with MF2 but I want to use TMPGenc to get them within the needed parameters. I would like to have an easy way of knowing the parameters of my mpeg files. An example is how Windows shows the details of AVI files. I know how to get the parameters in media player but it is cumbersome to use that.
"EL EXTRANJERO ME SIENTO"
ENRIQUE BUNBURY -
When you run MF-2 in dvd project mode click on the project icon in lower left of screen. as you click on any of the pre-sets it will display the properties
snafu099, I already knew how to do that.
I would like to have an easy way of knowing the parameters of my mpeg files. An example is how Windows shows the details of AVI files. I know how to get the parameters in media player but it is cumbersome to use that."EL EXTRANJERO ME SIENTO"
ENRIQUE BUNBURY -
Maybe this will help, maybe not... After adding mpegs to the project in DMF2, right click on an mpeg and select properties. That should give you some info about the resolution, size, etc.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
IE8 - unable to view drop down lists. Help!!
By thegeeman in forum ComputerReplies: 4Last Post: 18th Aug 2010, 11:01 -
Codec drop-down lists?
By terrypin in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2009, 08:34 -
Searching program for multiple cuts/splits in Mpeg-files
By tomk in forum EditingReplies: 1Last Post: 5th May 2008, 04:48 -
How do you get Explorer file lists to print?
By ahhaa in forum ComputerReplies: 13Last Post: 28th Jan 2008, 11:34
