I have captured a basketball game from Win TV and it was saved to my Hard Drive in MPEG format. Is MPEG the best format to use for DVD or do I need to convert to something different. If so what type file should I convert it too and which program should I use?
Are you sure that you captured in MPEG-2 format, not in MPEG-1 format? Only MPEG-2 is DVD compliant format...
Arek -
Whoa! Please do not tell him that!
Here are the valid formats for DVD:
PAL
Video:
Up to 9.8 Mbit/sec MPEG2 or up to 1.856 MBit/sec MPEG1 video
720 x 576 pixels MPEG2
704 x 576 pixels MPEG2
352 x 576 pixels MPEG2 (Same as the CVD Standard)
352 x 288 pixels MPEG2
352 x 288 pixels MPEG1 (Same as the VCD Standard)
25 fps (frames/second)
NTSC (NTSC Film)
Video:
720 x 480 pixels MPEG2
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
29,97 fps (frames/second)
23,976 fps with 3:2 pulldown = 29,97 playback fps (NTSC Film, this is only supported by MPEG2 videoHello.
How to capture a photo off a dvd or a video file?
By scustalow in forum Newbie / General discussionsReplies: 132Last Post: 8th Jul 2017, 13:12 -
Speeding up DVD file generation after capture
By trents in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2010, 00:03 -
If I have a video capture file that is 8 gb
By pugvader in forum EditingReplies: 21Last Post: 1st Jan 2009, 23:42 -
Can I capture while encoding a different file?
By tygger in forum Newbie / General discussionsReplies: 12Last Post: 22nd Jun 2007, 22:09 -
Capture DVD movie from a DVD player to a WMV file on my PC
By JBredensteiner in forum Capturing and VCRReplies: 4Last Post: 22nd May 2007, 02:49
