Hi, I currently use Adobe Premiere 6.0 for my video capturing. I have recently done a project which is 2 hours long, and around 20gb on my hard drive. When I try to burn it to DVD it says the file is too large for me to put onto the DVD. How can I compress it to make the 2 hours fit onto a DVD with out losing the quality? This is my first time working with DVD/r and I am trying to figure this out. Thanks for the help!!
If the file is an MPEG file, use TMPGEnc Plus or suitable substitute to extract the m2v and mp2 files from it. Change the file extension of the mp2 file to mpa. Open IfoEdit, select DVD Author-->Author new DVD. Load the video and new mpa file, select the folder to put the resultant files and "OK". The resultant files should be DVD files. Use DVD Shrink to compress them to fit on a DVD. Burn normally.
Hello. -
my dvd program (sonic mydvd) doesn't allow me to use diffrent files for video and audio... how do i make them one file?
Brandon19ec
I never heard of a 2 hour MPEG file being 20 Gigs. Is the 20 Gig file an MPEG or AVI file?
If it's an AVI then use TMEGenc to encode it to a Compliant DVD MPEG file. If it's an MPEG file the how was it made?
Regards,
Chas
large mp4 file to dvd
By GP_Wouter in forum Video ConversionReplies: 6Last Post: 3rd Nov 2010, 15:22 -
Burning large file onto CD or DVD
By Tom in HD in forum MacReplies: 3Last Post: 2nd Jan 2009, 16:06 -
Converted file too large for DVD.
By Dave H in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 18th Oct 2007, 20:08 -
Large Video File to burn to dvd
By jbristow in forum Authoring (DVD)Replies: 8Last Post: 15th Jul 2007, 04:49 -
How to get 14GB large mpeg-2 file to DVD?
By Bellman in forum Video ConversionReplies: 11Last Post: 20th May 2007, 20:38
