Hi, i have read the list of problems at the top of this forum, but i'm still having problems opening an mpeg 2 file in Tmpgenc. I have installed the mpeg2 codec and increased the Direct Show..... to the highest priority.
I am trying to convert an mpeg 2 to dvd, but every time i try to open the mpeg 2 in tmpgenc it says, unable to open file - not supported.
i have tried looking for the answer but cant seem to find it.
thanks for any help
it is greatly appreciated
Results 1 to 10 of 10
Try to open it in Virtual Dub mod. If it does open, then frameserve it to TMPGEnc Plau.
Hello. -
doesn't open in virtual dub either, it says "Mpeg Import Filter
ack synchronization error"
hey, it worked through virual dub Mod, but now i dont know what u mean by frameserve it to Tmpgenc Plus??
How do i do that?? -
Go to the Edit section, and look for framserve
Hello. -
i cant find anything in Edit section but in File section there is "start Frame Server" ??
I meant the Edit section of this site. Go there first, to make sure you have a good guide.
Hello.
Problem with converting MOV to MPEG2
By encAmateur in forum Video ConversionReplies: 5Last Post: 18th May 2011, 02:56 -
avi to mpeg2 burning problem
By deadwreck09 in forum MacReplies: 4Last Post: 19th Nov 2009, 13:17 -
Problem with mpeg2 decoder.
By tehuser in forum Software PlayingReplies: 5Last Post: 24th Mar 2009, 18:59 -
mpeg2 playback problem
By mike20021969 in forum Capturing and VCRReplies: 8Last Post: 26th Aug 2008, 09:25 -
Problem with Virtualdub-MPEG2
By deepakOne in forum Video ConversionReplies: 2Last Post: 5th Oct 2007, 02:35
