Results 1 to 11 of 11
  1. I've just used DVD Shrink 3.0 to shrink my DVD. Will Nero v5.5 burn my files for me, or do I need to create an ISO image?
    Any help for a Newbie much appreciated.
    Oct 2003
    Central Texas, USA
    Use the DVD-Video mode and make sure u put the ifo's, bup's, and vobs into the VIDEO_TS folder that Nero provides.
  3. Thanks for the reply, but I have another question. How can I select my Freecom DVD Re-writer as the recorder, cause It does not show. Only my Matshita DVD/CD-ROM drive.
    Nov 2000
    GLoucester
    Well you really are trying all the writing software arent you - Roxio and Nero.
    If Nero does not show up your writer, it is either cause you ASPI layer is messed up or your version of Nero is OEM and was supplied for a different writer, in which case you will need to register and purchase a serial number for it through AHEAD.
    TOMMO
  5. Why the hell do Nero (latest version of 6) take 3 hours to copy a disc on the fly??????? DVD Decryptor is taking long to burn an image file as well. I have the latest ASPI as well as DMA mode enable on all 3 of my burners as well as my hard drive. Nero fixes 1 thing then messes up something else.
    Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live!
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I hated Nero when it was only a CD Burning Program. I would NEVER buy that CRAP for DVD burning. Every other post here is a Nero problem/question.
    Same with Musicmatch.....tries to take over every aspect of every 120mm sized round object placed in the computer....CRAP.
    OK...I'm done venting....
  7. I hated Nero when it was only a CD Burning Program. I would NEVER buy that CRAP for DVD burning. Every other post here is a Nero problem/question.
    Nero works great for burning DVD's and has for many versions. The NERO IS CRAP club is made up of people who had trouble with some early version of Nero and for some reason took it very personally as can be seen from the above post.
  8. I've always boasted Nero above most proggys, however the last 3 updates to vs 6 of nero has created in a slow burn. If nero techs fixes the slow burn progress it will b on top of others as usual. For now I use eazy CD 6 platinum for my iso burns because DVD Decrypor is burning slow as well in Iso write mode, 7 for regular burning I use Stomp Recordnow max platinum.
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Excuse me but this IS yet ANOTHER post with a question/problem with Nero isn't it? Nero "does not play well with others". If you have ANY other CD or DVD related product on your computer WITH Nero....you end up here posting. THAT in my book is CRAP.
    DVDDecrypter burns and rips at the max speeds my drives will allow....because I don't have Nero on my computer.
    Nero is nothing but problems unless it is your ONLY CD/DVD application.
    CRAP!!!
  10. Originally Posted by hech54
    CRAP!!!
    ]Others here swear by the Recode 2 feature of Nero. I myself think it's ok, but not as good as IC vs 8. The only problem with IC 8 is it locks your drives disabling the use of ANY DVD, DVD IDLE, REGION FREE etc, So i had to uninstall.
  11. Excuse me but this IS yet ANOTHER post with a question/problem with Nero isn't it?
    Well, You've run rings around me logically. Let me see if I understand your point. Someone asks if Nero will burn DVD shrink files, (It will) and in your book this counts against Nero?
