  1. Hello Everybody!!!!!!!!
    Just wondering is there anyway to rip 2 dvds then put them both on a single disc but with their original menus and insert a menu to choose which movie submenu to go to.
    thank u in advance!!!!
  2. suppose you could use dvd shrink to rip the 2 dvd's and then use something like tmpgenc dvd author to get them burned together under one main menu.
    but, if the combination of those 2 dvd's adds up to more than 2 hrs running time, you'll most ikely see a significant video quality loss in the finished disk from the heavy amount of data compression needed.....good time to use rw disks if you decide to continue.
  3. Member steptoe's Avatar
    Try this link, read the guide a few times first, its a bit messed up here and there
    I've an improved version I've changed and added to but its in .doc format, so I can't post on here as it don't accept .doc files
    Mail me using PM, and I'll mail it to you, its only small, but in the wrong format to add to the foums guides
    http://www.dvdrbase.com/archive/index.php/t-31390
  4. Thanks a lot!!!!!!
    I have acheived my goal
    Redding, California
    DMXiNc
    You say you put 2 DVDs on 1 DVDR with original menus. I thought this was impossible. Could you tell us how?
    Chas
