I just got a DVD burner about 3 weeks ago. My DVD player didn't play ANY DVDr's so on the 26th I went and bought a new one(Toshiba sd-430). Now I have finally figured out the basics of authoring but the problem is unless I change the audio output to pcm I get no sound. But if I don't have it in bitstream I don't get 5.1 on my other DVDs.
So I am asking how do I get audio without having to switch to PCM?
Is there something I am missing while encoding, or authoring, or should I just say screw it take the player back and get a different one?
Also in AC3machine what should the "dll name" be?
Let me guess, you are authoring DVD's with mp2 audio. Your system is set up to output the audio to an external amp/decoder?
In that case author your DVD's with PCM or Ac3 sound and you won't need to change the output settings.
How to switch DVD audio channel positions?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2010, 13:29 -
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 23:17 -
Audio options in DVD player, RAW or PCM?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Dec 2009, 06:00 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 22:07 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 16:51
