Not +R, not -R, not -RW, not -RAM ... but DVD+RW
I've got a new APEX DRX-9000 recorder (an awesome machine, better quality than the Panasonics in 4-hour mode with no problems visually), and find myself wanting to use the DVD+RW discs most.
I will copy the DVD+RW to DVD-R when full, so I only need up to 25 of them at most. Prefer a 10-pack.
I don't want to pay more than $3 per disc. But I also don't want junk.
If I walk into a local store (be it Fry's, Best Buy, OfficeMax, etc), what is a good brand (and/or MEDIA ID) that I should look for?
I know all about DVD-R/RW and DVD+R formats, it's the DVD+RW that I never really use, so not sure if the RITEK/MXL/RICOHJPN/TDK crowd exists or is still top dog for the DVD+RW scene.
Help appreciated. Wanting to buy some today or tomorrow. Only have 3 to use at the moment.
Memorex 2.4 +RW, id INFODISC, regular price 25 for $40 at Fry's.
I also picked up a 10 pack of Memorex 4X +RW on sale there for $25 a while back, id RICOHJPN. Regular price is $40-$50.
The last time I bought HP media, it was also RICOHJPN.
All have worked fine in a Philips recorder. -
I have had great sucess using HP DVD+RW RICOHJPNW01 media code, burnt over 20 (mainly video and some data) with no coasters or failed burns, they scratch fairly easily but not if you take care of them, and no more than normal. This particular Ricoh code is 2.4x, the 4x code is RICOHJPNW11 which i know the new fuji+rw discs use, although ive had no experience of. I can recommedn this media, stands up well to rewrites, depends on price, i got a good deal on mine.
Generic disk that came with Lite On recorder
Media Information
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID RICOHJPNW11
Format Capacity 4.38GB(4.70GB)
Book Type DVD+RW
Media Type DVD+RW
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
BG Format Status Suspended
Data area starting sector 30000h
Data area end sector 23053Fh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
Phillips Media Information
Media code/Manufacturer ID PHILIPS 041
Book Type DVD+RW
Media Type DVD+RW
Number of Layers 1
I keep writing over both these disks without any problems. the last project put 4.32GB(4.64GB) on the Phillips disk and it played well in my Pioneer deck. -
HP is using CMCMAG for 2.4x DVD+RW at OfficeMax. Yuck.
Back to the store to try again. Gonna go give Fry's a shot.
INFODISC, huh? Anything's better than CMCMAG.
Gonna keep my eye out for the FUJI 4x RICOHJPN. Or the Philips ones.
Thanks. So far.Want my help? Ask here! (not via PM!)
Originally Posted by elmotheteapot
DVD Info says :Format Capacity 4.38GB(4.70GB)
The point being that the disk is full nearly to the end and it plays without drop outs. (Phillips 4x RW)
create high quality dvd
By happyjays123 in forum Newbie / General discussionsReplies: 5Last Post: 11th Sep 2011, 21:12 -
high quality .mkv from DVD?
By avextraxjp in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2010, 23:28 -
DVD to AVI (high quality)
By bob_smitty in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2009, 09:39 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33 -
I need a high quality DVD Burner
By efb91 in forum Authoring (DVD)Replies: 4Last Post: 25th Sep 2007, 16:38
