Help.Ive got two d/loaded movie files that i want to convert and put onto one dvd.Ive read all the how to's but am still getting stuck at the same point.
Extracted the mpegs with vcd gear (success)
Joined the mpegs with easy video joiner (success)
Trying now to re-encode mpeg1 to mpeg2 with Mainconcept mpeg encoder
It does the first part fine but when it comes to the join it stops and says that the files werent joined correctly.
Ive watched the mpeg with the join and the picture does go funny for a split second but doesnt sop with either wmp or power dvd.Do i need to edit the joint somehow?.Can anybody help.
Thanks in advance.
Results 1 to 19 of 19
Try SVCD2DVDMPG, here's a guide. Read step C, "never join your source mpegs."
You don't need to re-encode your mpegs if they are VCD's. Quality suffers, it takes longer and they are DVD compatible already.
You don't need to join your mpegs, it causes glitches and sync problems and the files can instead be authored together.
BTW, there's several ways to accomplish what you're attempting. Look in the guides under format conversion - VCD to DVD.
Hope that helps.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks for the reply ZippyP.But im not sure what im doing wrong.I am following a "How To" and have managed to get hold of all the programs it uses.I tried to join the two parts with Tmpgenc but just got audio sync problems.
I dont understand what you mean when you say vcd's are dvd compatible already.When i tried to author with tmpgenc dvd author i just got a load of red fatal error messages.
Need more help explaining what im doing wrong i think. -
Let me get this right.
For Tmpgenc Dvd Author to open the file it must be a svcd?
If i try to encode the two parts separate then author them sperate i get a clash with the two sets of numbers (vobs and ifos) when i try to burn with nero.Or am i doing this wrong too?.
I need help and quick -
Which "how to" are you following?Originally Posted by maureen
VCD video should be 352x480 resolution mpeg1 which is acceptable for DVD as well. The audio, however, is not DVD acceptable and you will need to convert it from 44.1 KHz to 48 KHz. It's all covered in one of the VCD to DVD guides."Art is making something out of nothing and selling it." - Frank Zappa -
No, SVCD2DVDMPEG does VCD as well, if that's what your thinking. SVCD resolution of 480X480 is not DVD compliant but many DVD players will play such a disk.Originally Posted by maureen
Encode separate, author together if that's the route you're choosing to go. Put them into the authoring step at the same time.Originally Posted by maureen"Art is making something out of nothing and selling it." - Frank Zappa -
Mpg1 is 352x240/288 and mpg2 is 352x480/576 1/2 dvd and 720x480/576 full dvd,is it not?
Those are the valid DVD resolutions, although the 352X240/288 can be mpeg 1 or 2.Originally Posted by johns0"Art is making something out of nothing and selling it." - Frank Zappa
ok,i`ve dealt with those types of resolutions in the past,my concern was on the dvd side of compatibilty.
I think thats the line that johns0 was referring to, and is incorrect. I am sure you meant 325*240Originally Posted by ZippyP.
Thats the line i was taking about so i did a test and made a mpg1 352x480 clip and tmpgenc dvd author accepted it without argue.
Yes, I was referring to VCD resolution.Originally Posted by bugster
But did it play?Originally Posted by johns0"Art is making something out of nothing and selling it." - Frank Zappa
Ill do a longer clip at that res and burn it just to see if it plays,ill keep you posted on the results,just encoding something else now.
Tmpgenc dvd author accepts 352x480 mpg1 and authors it and burns and plays no problem,just had to try it out,have to set the video arrange mode to full screen in tmpgenc.
I've got at problem with this, when I try to add a file with 480 verticale lines in Tmpgenc dvd author it cant read it. Something about GOP ... Also the 30fps should be 25fps for PAL...Originally Posted by ZippyP.
Whar to do? -
For tmpgenc dvd author to accept a mpg 1 and 2 files they should be 352x240/288(mpg1),352x480/576(mpg2) 720(704)x480/576(mpg2) and gop frames limited to 18 frames maximum for all mpg`s and audio has to be 48khz mp2 or ac3 or lpcm,some dvd players cant play mp2 so ac3 and lpcm are more widely accepted.
How can I change GOP frames so tmpgenc dvd author can accept it?Originally Posted by johns0
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
