I am using this card and so far am very happy with it, except that everytime I start it I have to reset the recording source on my sound card. Old Soundblaster PCI. I had a SB Live in there and it did the same thing. Any ideas on how to lock this???. If I set it for a timed recording when it starts up it dosnt record sound. Thanks in advance.
I doubt the card is at fault. I have the same one
Might be the program you are using to capture with that doesn't save your settings. Have you tried the WinFast PVR software that came with the card? I haven't had any problems with scheduled programs recording sound using that.
I always have to select my sound card with many other programs everytime I start, unless it has a save settings option. -
Thanks for the reply. I am using the Winfast PVR. If I schedule a recording and then just minimize the program it is fine. When ever I start the program though I have to reset my recording properties. I have even set the recording control and left it on the screen and when I start PVR the check mark disapears.
hmm
Have you tried downloading the updated PVR software from the leadtek website? Thats the one i'm using. I didn't install anything from the disk that came with the card. I downloaded all the updated drivers and software from the site. Have had no problems
Maybe something got fixed in the newer version. Try it out -
Just installed this card 2 days ago and am still playing with cap settings.
Curious did you change the default audio inputs or not connect the audio wire to sound card? I did nothin in "volume" properties settings
w98se, onboard sis sound. cd installed software/drivers -
No everything is set up properly. I'm using Win XP Pro. I used the drivers and app off the CD dated 9-03. Its just very strange
New driver & PVR software dated 31 Dec 2003 is now available. Try them.
Honestech VHStoDVD 5.0 deluxe
By Regor21 in forum Capturing and VCRReplies: 0Last Post: 2nd Mar 2012, 08:39 -
Magix video deluxe 15 plus
By croarta in forum EditingReplies: 1Last Post: 11th Sep 2010, 06:10 -
Powervcr II 3.0 Deluxe
By vijaye05 in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2008, 05:30 -
Xitel (INport Deluxe)
By grom in forum AudioReplies: 0Last Post: 22nd Jun 2008, 21:42 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01
