Hi
I have a problem playing VCD's and backed up DVD's on my DVD Player. (multiregion) It is VCD/CD-R/DVD-R compatable but plays backed up DVD's in black and white. Orginial DVD's will play fine while VCD's even orginals play without colour.
Any help???
thanks
Results 1 to 11 of 11
Could the DVDs/VCDs have been burned into PAL and the DVD player set to NTSC or vice versa?
Hello. -
right, changed the settings to PAL and the VCD's play fine
As with the DVD's when the DVD Player is set to PAL a error message appears saying "Not PAL" When I switch the settings back to Auto the DVD's play in black and white.
thanks again
Luke -
I have now found out that this only occurs when playing reigon 1 DVD's on my multi reigon DVD player.
Does anyone know why this happens???
Plz help!! -
Region 1 DVD's are NTSC. Your DVD player will probably output an NTSc signal whne it sees NTSC format DVD's. Your TV needs to be able to handle this or you get B & W pictures.Originally Posted by luke_503
Its a fairly new tv, 3-4 years old and is a Sony Truton, so really I will need a new TV?
Either the TV or the DVD player doesn't output NTSC properly. You can probably get some sort of external NTSC->PAL doohicky, but I don't know where offhand.
- Gurm -
- Gurm -
Check your DVD players set up menus or manuals. SOme have the option to output NTSC material as either NTSC or PAL-60. If you can, switch it from whatever it is now to the other and see if it fixes the problem. I would expect your TV to be able to handle at least one of these.
tried what you all said but with no look.
Does anyone know if there is a converter or special scart leader or anything that I can buy and where from??
thanks guys -
Get a computer and use a TV out card. That should get rid of your NTSC/PAL problems.
Monitors and colour.
By dfgh11 in forum EditingReplies: 3Last Post: 6th Jan 2011, 10:44 -
Help with colour banding...
By FNi in forum EditingReplies: 6Last Post: 2nd Oct 2010, 20:15 -
Menu Colour
By sambat in forum Authoring (DVD)Replies: 0Last Post: 26th Apr 2010, 07:54 -
Subpicture Colour Changes
By sambat in forum SubtitleReplies: 2Last Post: 1st Apr 2009, 19:54 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
